14 years ago[Target Connection]: No Nios II target connection paths were located. Check connectio
Hi all. I'm running quartus web-edition 12.0, on win7 64 bit. I'm using cyclone II starter kit. i ran through the nios2 hardware tutorial and downloaded the software correctly. afte...
14 years agoso, you have checked timelimited module?
and that is fine, isn't it? then check signals reset and clock to NiosII you can check those signals in signal tapII if you don't know signaltapII there is a document for that. http://www.akiron.com/fpga/baseprojectinverilog.zip see you.
