17 years agosystem runs whilst debugging but not on its own
Hi, I have a custom board with an EP3C40F484C6, EPCS64, DDRII and an LCD touch panel. I am using quartusII 9.0 and NIOSII EDS 9.0. When I use the niosII ide to run my program within the hardwar...
17 years ago1 - Are you using a jtag uart and if so are you printing anything to standard out? If so, you may be overflowing the jtag uart's buffer at which point the system will hang indefinitely.
2 - Is your processor configured to boot from the EPCS device? 3 - Is your processor configured to run out of onchip memory or some other memory? 4 - You should use the nios2-flash-programmer to program the EPCS device rather than the QuartusII programmer. Jake
