12 years agosystem.h not reloading
Dear all
I have the problem the system.h is not reloading if in my nios II project even if I regenerate the bsp stuff. And it is a little bit more strange: New defines are not visible. Old definitions are still visible but if I chose "Open Declaration" Eclipse opens the correct system.h with the correct value (even with the new definitions) but I points to wrong location. So for me it looks like there is someting like precompiled version of system.h available but I did not find it. I have only two projects in my workspace the bsp project and the other one created at the same time. I can delete the system.h and then it is not available anymore in both projects. But if I regenerate the bsp I still have the same problem. I also tried to clean up and rebuild both projects without difference. I know about the existing topic: http://www.alteraforum.com/forum/showthread.php?t=13057 This seems to be a very similar problem but not solved so I reask the question. I use Quartus II 13.1.0 Did anyone else have such problems? Best regards and thank you in advance. Dominic3 Replies
--- Quote Start --- I created a new workspace, copied files and appropriate makefile sections and it works now. But still something is wrong. If i add manually for example:
In my fill i can't see test macro ("selected text cannot be mapped to symbol name"). How does it really work and if there is a workaround ? best, madness --- Quote End --- It's the indexer issue. One must simpl right click on the project go to Index -> Rebuild and Index -> Freshen all files. best, madness#define test 0 - Altera_Forum
I have exactly the same issue ! It makes me go mad. I'm using quartus 12.1sp1 and I have tried I suppose everything exepct creating a new workspace and importing a project one more time. Does anyone have any ideas ? Best, madness - Altera_Forum
In my fill i can't see test macro ("selected text cannot be mapped to symbol name"). How does it really work and if there is a workaround ? best, madness#define test 0
