9 years agoSystem doesn't keep programming
I'm very new to using FPGA's and I'm having a small issue using the the Max10 Eval Board. I'm able to create a system and program the board fine but every time the board looses power (I unplug it an...
9 years agoIt's has two MAX10 EVA BOARDs, one is 10M08S, the other one is 10M50.
which EAV you program? if it's 10M08S, you can follow the doc start at page 3-4 "Generating a .pof File with ICB Settings" https://www.altera.com/en_us/pdfs/literature/ug/ug_max10_eval_10m80.pdf if your EAV board is 10M50. you can start at page 3-21 "Flash" as below doc https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/products/devkits/altera/documents/10m50_evaluation_board_userguide.pdf
