15 years agosystem design using cyclone II
Hi, I am trying to implement a hardware system which uses current to compute distances. The incoming current is obtained from a sensor, and will be sampled and input into my FPGA. The ADC is 14...
15 years ago --- Quote Start --- I have finished my MATLAB model of the lock-in amplifier and tested on the training data. It works greatly. Thank you very much for your kindly help!! --- Quote End --- That is great! --- Quote Start --- Now I am facing the challenge of implementing the amplifier in FPGA (which I assume is much harder than the previous work...). Since the lock-in amp consists of PLL, NCO, mixer and filter. I used the megacore function to generate each part. The design of filter is a little bit confusing. I need to design a CIC filter followed by a compensation FIL filter. In my case, the sampling frequency is 4Mhz, the frequency of interest is 154khz, the passband width is 1khz. So I probably need a bigger downsamping factor, I set it to 128. The CIC parameters: input signal datapath 16bit, R=128, N=9, M=1, full precision data length is 16+N*log2(R*M)=16+9*7=79bit. Since I want 16bit output, the megafunction uses Hogenauer pruning technique to reduce the data widths. The FIR design: Megafuncton would generate a matlab file that can generate a compensation filter. The coefficients would be loaded into QuartusII and generate the FIR filter. Am I on the right track? --- Quote End --- Yes, you are on the right track. Before getting too involved in the Quartus solution, go back to MATLAB and look at their CIC and compensating FIR designs. I think they have a downconverter example that shows how to use it, or perhaps it was the book by Losada (available on the MATLAB site). Gain an understanding of how the CIC filter works first, and then what the compensating FIR filter is being used for. Only once you understand that, should you begin the implementation in Quartus. Cheers, Dave
