15 years agosystem design using cyclone II
Hi, I am trying to implement a hardware system which uses current to compute distances. The incoming current is obtained from a sensor, and will be sampled and input into my FPGA. The ADC is 14...
15 years ago --- Quote Start --- here is the link for the PSD: "en.wikipedia.org/wiki/Position_sensitive_device" --- Quote End --- Ok, thanks. --- Quote Start --- the modulation is performed in the analog domain by somebody else. I dont have a clear mind of what the process is, I can ask him if this is really important to my design. --- Quote End --- It is the light that is being modulated, so that you get modulated currents at the output of your sensor. The reference of the 154kHz modulation source is important, because the sensor processing needs to be synchronous with that source. --- Quote Start --- Here is a piece of code I found on line which can transfer a clock into a sine/cosine wave ... --- Quote End --- This is just a very simple NCO. --- Quote Start --- so, if the code works, instead of using NCO, I can transform a square wave into a sine wave right? as long as I get a 154Khz clock. --- Quote End --- I doubt the code will work for your application. The Altera NCO component is simple to use. You can also implement sinusoid tables using ROM. At this point, you are still trying to understand all the components in your system will fit together. So for now, just assume you will be using 'something' that creates sine and cosine samples inside the FPGA, and they will correspond to samples of a 154kHz sinusoid. The generic name for that 'something' is NCO (regardless of whether you use the NCO component from Altera). You now need to determine how the light modulation will be synchronized to your signal processing system, so you can accurately measure the demodulated currents. Cheers, Dave
