12 years agoSynthesizable delay with VHDL (One single output pulses)
Thanks in advance for your nice instructions. What I am doing is producing a single output pulse. It is a simple output but due my little knowledge it becomes complicated for me. What I want in ...
12 years agoI might have not got the clue on your Intention, but in case you just Need one pulse when the FPGA goes online, this should be possible by just implementing a Counter that starts couting with every rising edge of clk as Long as the final value is not reached. the Output can be set high for countervalue being higher than x (this is the number of clocks delaying the high pulse) and being lower than y (with y-x defining the pulse width):
signal Counter : integer range 0 to 1023; signal start_delay : integer range 0 to 1023; signal pulse_width: integer range 0 to 1023; process(clk,POR) begin if (POR='1') then Counter <= 0; Output <= '0'; elsif rising_edge(clk) then if (Counter < 1023) then Counter <= Counter+1; end if; if (Counter < start_delay) then Output <= '0'; elsif (Counter < (start_delay+pulse_width)) then Output <= '1'; else Output <= '0'; end if; end if; end process; The POR signal is a internally generated (or external applied) PowerOnReset signal - not functionally necessary... I just wrote this here - did not check for Syntax in QII yet, thus excuse any typo...
