12 years agoSynthesizable delay with VHDL (One single output pulses)
Thanks in advance for your nice instructions. What I am doing is producing a single output pulse. It is a simple output but due my little knowledge it becomes complicated for me. What I want in ...
12 years agoAnother point, In the below mentioned code I have a pulse like this [SUB]----0---[/SUB][SUB]----0---[/SUB][SUB]---0----[/SUB][SUP]-----1----[/SUP][SUB]----0---[/SUB][SUB]----0---[/SUB][SUB]---0----[/SUB][SUP]-----1----[/SUP]. The point is that I need only the first "1", I do not need any pulses any more. But as I have to control the pulse width of my signal (When the output is "1") therefore I need to use counter.
I have used the type command and two state (idle and delay). After idle state it goes to delay state and if it was (c=a) output become 1 and if it was (c=b) output become 0 (Because I need to control the pulse width). After it becomes 0 it goes again to delay state. I have tried many other options to don't let goes to idle after delay state. What is your suggestion for rejection of repetition. I mean, only one pulse in output with width controllability?? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity delay_auto is port ( clk : in std_logic; data_out: out std_logic ); end delay_auto; Architecture behavioral of delay_auto is signal c : integer:= 0; constant a : integer:= 5; constant b : integer:= 6; type state_type is (idle, delay); signal next_s: state_type; begin process (clk) begin if (rising_edge(clk))then case next_s is when idle => c <= c + 1; next_s <= delay; when delay => if (c = a) then data_out <= '1'; end if; if (c = b) then data_out <= '0'; next_s <= idle; c <= 0; else c <= c + 1; end if; end case; end if; end process; end behavioral;
