17 years agosyncronous clocks
This may seem a like a stupid question, but I am new to Altera FPGA's. When using a PLL to generate syncronous clocks, lets say a base clock and a base clock multipled by 2 for example, can I assume ...
17 years agoBasically you should always sample your data at the right speed. So you can't feed data from slow clk to fast clk unless you control the rate through enable signal. As you said, an enable signal is better than multiple clk system if that is feasible.
