16 years agosynchronous process on both edges
Dear All, is is possible to create a synchronous process reacting on both clock edges? Is it synthesized? Or I have to use PLL to go for twice higher clock frequency and use only rising_edge? ...
16 years agoHi,
no, a process that is sensitive to both edges cannot be synthesized, at least not in a FPGA. The general solution would be to use a PLL. Of course, in some application cases you can get the job done by using two different processes on the two clock edges. The most relevant case is DDR I/O.
