10 years agosynchronous data in, synchronous data out issue
I have a single data rate edge-aligned (video) input signal consisting of the following lines: IMAGER_PCLK (the pixel clock) IMAGER_VSYNC (vertical sync pulse) IMAGER_HSYNC (horizontal sync pu...
10 years agoYou've generated a gated clock in 'ECU_PCLK'. Gated clocks are not a good idea and often result in, as you've seen, timing problems. However, I'm not sure that's a problem...
--- Quote Start --- I want to have a process that latches the input signal --- Quote End --- So, when 'imager_pclk_latch' is active (high) 'ECU_PCLK' simply latches the state of 'IMAGER_PCLK'? Is that right? In which case 'ECU_PCLK' isn't a clock. However, you've constrained it as one in your generated clocks section. You've also constrained 'ECU_VSYNC', 'ECU_HSYNC' & 'ECU_DATA' with respect to 'ECU_PCLK'. However, (I'm pretty sure - you've not posted all the code) they're not generated from this clock. Does your code do what you're expecting - in simulation? What frequency is 'imager_pclk_latch'? I think I need a more complete picture to fully help. Cheers, Alex
