17 years agosynchronize pll
On CycloneII, is it possible to re-synchronize or start a pll on an async event such as a pulse?
I have a 50Mhz pll clocked state machine that is triggered from a single external async pulse. I also have a Flash A/D that is running on a separate, continous 10mhz pll clock. What I would like to do is synchronize the two plls such that the A/D clock is aligned to my external pulse so its sampling times are predictably synched to my state machine logic. The A/D is designed to operate from a continuous clock only and has an internal 4clk conversion delay. The very first result may be bad but I can live with that. I thought of using counters to generate a 10Mhz clock directly from the 50Mhz state machine logic but it would be better if I could use a pll so as to have some control over phase.
