18 years agosynchronize pll
On CycloneII, is it possible to re-synchronize or start a pll on an async event such as a pulse? I have a 50Mhz pll clocked state machine that is triggered from a single external async pulse. I...
18 years agoThe Quartus Handbook clarifies that DDIO can't be inferred from HDL code:
--- Quote Start --- You must instantiate megafunctions to target certain device and high-speed features such as LVDS drivers, PLLs, transceivers, and double-data rate input/output (DDIO) circuitry. --- Quote End --- Other solutions that combine posedge and negedge clocked registers are possible, but you have to take care not to generate glitches. One option is to use a asynchronous clear from a register clocked at the opposite edge. See: http://www.edaboard.com/viewtopic.php?t=303735
