18 years agosynchronize pll
On CycloneII, is it possible to re-synchronize or start a pll on an async event such as a pulse? I have a 50Mhz pll clocked state machine that is triggered from a single external async pulse. I...
18 years agoThis short code works pretty well. Functional sim looks perfect but timing sim does not init properly. On CII grade8, a 50mhz:10mhz conversion has 50% duty. I don't see glitches, but it does not always start aligned to the 1st rising edge like I want. Could be improved.
--- Quote Start --- module ddrdiv5_clk ( clk50, nReset, cnt_en, clk10_out ); input clk50; input nReset; input cnt_en; output clk10_out; reg[4:0] ddsrh; reg[4:0] ddsrl; reg first; assign clk10_out = ddsrh[0] & (ddsrl[0] | ~ddsrh[4] | ~ddsrl[4]); always @(posedge clk50 or negedge nReset) begin if(!nReset) begin ddsrh[4:0] <= 5'b01110; first <= 1'b0; end else begin if(cnt_en) begin ddsrh[4:0] <= {ddsrh[0],ddsrh[4:1]}; first <= 1'b1; end else begin ddsrh[4:0] <= ddsrh[4:0]; end end end always @(negedge clk50) begin if(!first) begin ddsrl[4:0] <= 5'b00110; end else begin if(cnt_en) begin ddsrl[4:0] <= {ddsrl[0],ddsrl[4:1]}; end else begin ddsrl[4:0] <= ddsrl[4:0]; end end end endmodule --- Quote End ---
