15 years agoSynchronization problem in PWM generation
I am using the DE2 board to generate a 20 kHz PWM signal. The duty ratio is constant 20%. The device is implemented by verilog. My method is to use DE2 board to generate a 20 kHz * 1000 = 20 MHz cloc...
15 years agoYou should use a synchronization chain as described in the Quartus Software Handbook and logic design text books.
always @(posedge clk)
begin
pwm_trig_s0 <= pwm_trig;
pwm_trig_s1 <= pwm_trig_s0;
if (pwm_trig_s1==1) //control the slope of the triangle wave.
b=-1;
else
b=1;
end
