15 years agoSynchronization problem in PWM generation
I am using the DE2 board to generate a 20 kHz PWM signal. The duty ratio is constant 20%. The device is implemented by verilog. My method is to use DE2 board to generate a 20 kHz * 1000 = 20 MHz cloc...
15 years agoPlease check altera.com I think there is a proven PWM generator. The example is n-bit resolution.
