15 years agoSuper loop simple socket server design example
I am trying to run the design example super_loop_simple_socket_server plus using Quartus II version 10.0sp1. that is found in the following link: http://www.alterawiki.com/wiki/superloop_simple_socket_server_plus After successfully extracting the folder using NIOS II command shell, when writing the following command (as found in the read me file.): create-this-app --cpu-name linux_cpu The following error was encountered: create-this-app --cpu-name linux_cpu command not found. Can any one advise me on this issue. The prompt response is highly appreciated. Thanks & Regards.No RepliesBe the first to reply
