15 years agoSuper loop Ethernet connectivity
Hello, I am using Quartus II 10.0sp1. I'd like to implement an Ethernet connectivity using the super loop (without using uc/OS-II). I failed to run the design example found in altera wiki...
14 years ago --- Quote Start --- Hi, I am using Cyclone III development board & I successfully ran the simple socket server on it. If you need any help you are welcomed. Thanks & Regards. --- Quote End --- Hello vlsidc, I also have SSS with uCOSII running on the Cyclone III NEEK, but having difficulty getting it to fit on my custom board that has only 512MB of SRAM rather than the 1MB SSRAM that is on the NEEK system. I am desperately tring to get the SSS, or even better the SSS Plus, working in a smaller SRAM footprint. Superloop mode of SSS Plus seems to be a good direction for me, but I am still struggling to implement it. Fisrt on NEEK, then on my board. Do you have experience with SSS in Superloop running on NEEK or any other platform? PS: I am working with Quartus II v11.0 sp1
