15 years agoSuper loop Ethernet connectivity
Hello, I am using Quartus II 10.0sp1. I'd like to implement an Ethernet connectivity using the super loop (without using uc/OS-II). I failed to run the design example found in altera wiki...
15 years ago --- Quote Start --- So you have been unable to get this working still? If that's so, if I get anywhere I'll let you know. What have you tried or looked at so far? Another option I'm looking at is the webserver example for the de2-115. --- Quote End --- I did not yet solve this problem :(. I am trying to browse the NicheStack library as well as the simple socket server source files to find what I should make to use the superloop mode. I really appreciate your support. Thank you.
