8 years agoStratix5 - VCCCORE to GND resistance is almost 0 ohm
Hi, We have designed a PCB for the Stratix V device. We found the resistance between VCCCORE and GND is almost 0 ohm, thus we never powered it up. To clarify the problem, FPGA was di...
8 years agoHi Vina,
1.Do you have any spare FPGA so that you can probe and compare. If you are sure on the 0.02 ohm, than FPGA may be damaged. or You can submit a request to mysupport for FA(failure analysis). 2.If board is not powered ON than FPGA may be fine. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
