8 years agoStratix5 - VCCCORE to GND resistance is almost 0 ohm
Hi, We have designed a PCB for the Stratix V device. We found the resistance between VCCCORE and GND is almost 0 ohm, thus we never powered it up. To clarify the problem, FPGA was di...
8 years agoHi,
1.Are you sure you got 0.02 ohm after probing FPGA vcc core and Gnd? Re-check you may be probing some of other GND pins instead of Vcc core because of device pitch. 2.Have you checked the board ?(Converters, regulator & passive components in the path) It is a short as per your value. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
