allen18's avatar
allen18
2 years ago
stratix10 power configuration
Hello :
I am using the Stratix10-1SX110HN2F43I2VG, and the datasheet indicates that it is a smartVID device. So, I plan to use an LTM4677 to power it. The LTM4677 has two output channels. I intend to set channel 0 to an initial output of 1.8V for VCCPT, and channel 1 to an initial output of 0.9V for VCC, VCCERAM, and VCCP.
According to the Power Management User Guide, “The Secure Device Manager (SDM) Power Manager reads these values and can communicate them to an external power regulator through the PMBus interface”, If the SDM manages voltage by communicating with the LTM4677 via the PMBus interface, how does it know which channel to control ?
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    I’m glad that your question has been addressed, for now I will set this case to Close-Pending.
    Nazrul Naim
  • Farabi_Altera's avatar
    Farabi_Altera
    SDM communicate with power regulators via I2C signals connected between FPGA and regulators. The power requirement is feedback to regulators so it can regulate the correct voltage required by the FPGA on each power rails. This is done automatically and you need to use only supported power regulators in order to make sure the communication between regulator and FPGA has no errors.
    please refer to this link : https://www.intel.com/content/www/us/en/docs/programmable/757318/current/steps-to-decode-the-pmbus-transaction-log.html
    for more details.
    regards,
    Farabi
    NazrulNaim_Intel
    Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
    Thank you for your patience.
    Nazrul Naim
