allen18
2 years agostratix10 power configuration
Hello : I am using the Stratix10-1SX110HN2F43I2VG, and the datasheet indicates that it is a smartVID device. So, I plan to use an LTM4677 to power it. The LTM4677 has two output channels. I inte...
- 2 years ago
SDM communicate with power regulators via I2C signals connected between FPGA and regulators. The power requirement is feedback to regulators so it can regulate the correct voltage required by the FPGA on each power rails. This is done automatically and you need to use only supported power regulators in order to make sure the communication between regulator and FPGA has no errors.
please refer to this link : https://www.intel.com/content/www/us/en/docs/programmable/757318/current/steps-to-decode-the-pmbus-transaction-log.html
for more details.
regards,
Farabi
NazrulNaim_Intel
2 years agoHi,
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
