GDeXi
6 years agoStratix10 muiltboot configuration
I have two image in QSPI flash,both have PCIe funtion, It is hoped that the PCIe will not be hung up during image switching,There is some example design or user guide for provide reference. ...
YuanLi_S_Intel
6 years agoAssuming you are using active serial configuration scheme which you will program the flash first with PCIe. The image will not be programmed into FPGA from flash unless you have rebooted. Thus, it wouldnt affect it.
User1574410249703619
6 years agoI don't use PCIe to transfer the image file. just both image in the flash have PCIe function, when i use "mailbox ip" to update image , I just think there is some gap when switch to image . so that the host fail to recognize the PCIe during this time and hangs up.
image1 has PCIe function, and image2 has same PCIe function. the host driver will be failed when change two image using "mailbox ip"?
Thanks!!! have fun.
