11 years agoStratix V GT device receiver parallel data output incorrect
Hi, Just to share that in case you observe receiver data output issue with Stratix V GT, the following KDB solution might be helpful: https://www.altera.com/support/support-resources/knowl...
11 years ago --- Quote Start --- Hi, Just to share that in case you observe receiver data output issue with Stratix V GT, the following KDB solution might be helpful: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06242015_674.html --- Quote End --- Thanks for sharing the solution and the patch.
