Stratix IVGX (EP4SGX70HF35C3) PLL+SERDES issue
Hello Ramakrishna ,
If you plan to use the non -DPA mode , PLL which is driving the non-DPA mode SERDES should be compensated . LVDS Compensation option will be there in the PLL IP setting .In Non-DPA mode you have to make sure DATA and CLOCK compensate for the SKEW.
can you kindly refer below link document ? which contain full insight of LVDS SERDES IP. " Table 20 "
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altera_lvds.pdf
I thought you were just converting Verilog to VHDL from the TI example design .
Thank you ,
Sree
Hi Sree,
I selected the option of "In source-synchronous compensation Mode" and I still get the same error. I tried all possible options and I still get the same error. I can send my code, if it helps looking into this issue. Please let me know
Ramakrishna
