16 years agoStratix IV GX transceivers: 32-bit word alignment in basic mode?
Hi. I'm working on the transceivers of a Stratix IV GX series FPGA. The handbook covers word alignment quite well for smaller data widths (e.g. 8, 16), but is vague when it comes to word align...
16 years agoNext problem:
The byte ordering block can only be used when I select a 20-bit word alignment pattern length in the Word Aligner tab (instead of the 10 bit alignment pattern I now use). However, a 20-bit pattern is not recognized as a control code, and therefore I cannot align to a 20-bit pattern (rx_patterndetect never goes high). So eventhough I can now use the byte ordering block, it it still useless because now the byte alignment does not work anymore. Are there standard 20-bit control codes, equivalent to the 10-bit K28.5 alignment code 0101111100 (which is BC decoded to 8 bits)?
