16 years agoStratix IV GX transceivers: 32-bit word alignment in basic mode?
Hi.
I'm working on the transceivers of a Stratix IV GX series FPGA. The handbook covers word alignment quite well for smaller data widths (e.g. 8, 16), but is vague when it comes to word alignment of 32-bit data. The BYTE alignment works perfectly, but 4 bytes transmitted (e.g. x"123456BC" turn up on the receive side in 2 consecutive words: the 2 LS bytes in received word A, the 2 MS bytes in received word B: A xx xx 56 BC B 12 34 xx xx It seems word alignment of 32 bits (in basic mode) is simply not supported (by the ALTGX megafunction), which means I have to do the word alignment myself. Have I hereby answered my own question, or am I missing something here? [p.s. Admins: the post editor auto removes spaces, making it hard for me to 'draw' signals etc in text. Can this be solved?]9 Replies
- AVija7
i have followed all these steps, but was not able to get the data in the correct order?
how you gave your rx_enapatternalign signal and what about the rx_enabyteord?
I'm using the following alignment pattern: 0x0000BC1C BC and 1C are both 8/10b control bytes. In the megafunction, I'm using the following settings: -Basic mode -32 bits -8/10 endoding (obviously) -Manual word alignment mode (assert the rx_enapatternalign when you know the RX is receiving the alignment pattern) -Word alignment pattern is 20 bits -Word alignment pattern: 01011111000010111100 (= 0x5F0BC) Note: The alignment pattern is entered in the megafunction in its 10/8 encoded form, so 0xBC1C becomes 0x5F0BC. -In addition, I use a byte ordering block (based on the syncstatus signal of the word aligner) that triggers on the last 1C of 0xBC1C. As this 1C will be encoded as a control word, I entered 000000000 100011100 as byte ordering pattern where 00011100 is 0x1C and the preceding b'1 is the control_detect flag bit. So, to summarize, I put 0x0000BC1C on the 32-bit TX user data bus where the 0xBC1C portion is 10/8 encoded as control bytes (assert tx_ctrlenable to do this) and transmitted as 0x5F0BC. The RX side word aligns to this (when rx_enapatternalign is asserted) pattern and performs byte ordering using the last 0x1C. The I put my user data on the parallel TX bus and it shows up correctly on the RX side. p.s. - I assume the transceiver is initialized properly; that the analog and digital resets are released in the correct order and based on the pll_locked and rx_freqlocked outputs etc., as described in the handbook) - Altera_Forum
I've got a similar issue. But instead of your example my byte-ordering looks like this: A 34 45 78 xx B xx xx xx 12 Could you send me your solution? I hope it will work in my case too. Thanks, Stefan - Altera_Forum
Hi!
Could you please tell me the solution concerning the Word Aligner in transceiver channels of stratix iv devices? What is the problem in 'Basic double width' mode? Thanks - Altera_Forum
I'm working in this issue without success. Could you send me any code for synchronization? thanks, Fer, - Altera_Forum
What was the issue you were seeing when using the byte ordering block? Can you please explain further? Thanks, M - Altera_Forum
Fixed it - if anyone's interested in the solution, reply here or pass me a message...
Next problem:
The byte ordering block can only be used when I select a 20-bit word alignment pattern length in the Word Aligner tab (instead of the 10 bit alignment pattern I now use). However, a 20-bit pattern is not recognized as a control code, and therefore I cannot align to a 20-bit pattern (rx_patterndetect never goes high). So eventhough I can now use the byte ordering block, it it still useless because now the byte alignment does not work anymore. Are there standard 20-bit control codes, equivalent to the 10-bit K28.5 alignment code 0101111100 (which is BC decoded to 8 bits)? - Altera_Forum
I just found a section in the handbook covering an optional byte ordering block (page 1-91, vol. 2), seems just what I need for this application.
