16 years agoStratix II/III with no external oscillator
Hi I have a Stratix II GX and Stratix III dev board setup with no external oscillator, only connections for the FPGA are the JTAG and passive serial connectors. Does anyone have any exp...
16 years agoHi,
Thanks for the information. The term dev board may have been misleading. I actually have a socket and clamp board made specifically for configuration before the fpga actually goes onto an actual board. As the board was designed for configuration only there are no generic I/O available for testing, and obviously no oscillator. I am trying to prove that the configuration is actually occuring correctly using any possible software method. I may just try to use jtag chain debugger to do a boundary scan but I have not tried to do that before either and cannot seem to find much documentation on actually using jtag chain debugger (as opposed to what is is capable of) I will check out the linked project. Thanks again!
