17 years agoStratix III Remote Update
Hi all, for a Stratix III design I'm trying to choose an embedded reconfiguration scheme. Ideally I want to select a scheme where I can update the configuration device via a serial port with...
16 years agoJulie,
Typically, I never see configuration errors unless there is a legitimate problem with the bitstream. However, that may not be the case for your board. If you do feel you need to retry configuration several times then using I think the approach you've proposed is legitimate. You may also wish to use a simple eeprom or even an address in off-chip sram (that remains powered of course) instead if you've got such available just because the interface may be easier. Jake
