17 years agoStratix III LVDS OCT
Hello! I am using stratix III and I have a few questions about LVDS and OCT in stratix III and I/O buffers. 1. If we want to use dynamic termination, can we use differential mode? a. ...
17 years ago> Pseudo-differential operated single-ended buffers with serial termination have to be used instead.
I have a similar problem: The Synthesis reports: Warning: Pin OUTPUTp[0] must use pseudo-differential I/O standard -- the Fitter will automatically assign LVDS_E_3R pseudo-differential I/O standard to pin And later it says: Error: The differential I/O standard LVDS_E_3R cannot be used on the pin OUTPUTp[0], because the specified pin uses a tri-stated output buffer. How do I have to setup these pins in the assignment editor?
