17 years agoStratix III EP3SL340c3 Diffrential IO data rate
Hi I have been working on DE3 board with the above mentioned FPGA for some months now. I am trying to deserialize 8 LVDS channels from an ADC. each channel is 12 bits and ADC can work upto 50 Mega...
17 years agoWhy did I think this was Cylone III when the title clearly says Stratix III? I guess that shows the competence of the support you're getting. : )
There are some threads on it, but simulations, including timing sims, are a far cry from static timing analysis. They always use exact values, while static timing analysis is basically making sure the delays are within a range. Real hardware works that way, i.e. delays vary over Process, Voltage and Temperature. Just wanted to point that out. (Of course, Static Timing Analysis just says delays meet your requirements, but if you're logic is incorrect it won't matter, which is what simulations are for...)
