17 years agoStratix II GX Transceiver: Does 8b/10b coding work properly?
Hi again, I have limited the problem of undefined bits in the tx-output datastream to a problem with the 8b/10b-encoder. In ModelSim, I found the internal signal between the Phase Compensat...
15 years agoHi Daniel,
I'm working in the same topic as you encoding with 8b10b using SIIGX. I'm trying to syncrhonize my transceivers but I don't achieve it. Could you send me any example code?? Thanks, Fer.
