17 years agoStratix II GX Transceiver - Pattern recognition in rx-data
Hi, I have a transceiver-design with an optical loopback-wire. the datastream is a 32b binary counter with a clock of 120 MHz. My alt2gxb is configurated as followed: - basic mode, double dat...
17 years agoHi! First: Thanx for your quick reply, jake!
After getting the modelsim simulation library to work, I could see that there probably is a different problem with the TX phase compensation fifo. In modelsim, I see that in tx_digitalreset-mode the K28.5 word is transmitted. After reset time, the data word at the tx-input is arbitrary and constant "FF0F33FB". I looked up the 8b/10b-coding table of the handbook to see what my serialized signal should be. Instead seeing it, I get some undefined states in the signal; mixtured with the 8b/10b-coding. While searching for the reason, I found that some tx-internal values have undefined bits, too: sim:/testbench/u_0/u_7/nlilo/ser_datain: U00U1101010010111010 sim:/testbench/u_0/u_7/nlilo/wire_dprioout: UUUUU... later some 0 and 1 but always U inbetween. sim:/testbench/u_0/u_7/nlilo/td_in_txd and also pi_in_txd_ch, pi_in_txd_ch_dprio, pi_out_txd: 00U0000000000U0000000000U0000001000U10101111 Also, the debug_tx_phase_comp_fifo_error signal is U all the time. Daniel
