16 years agostratix II Dual-Piece Lid FBGA getting very hot
Hi, I have developed a test board that is approx 6" x 8" with a stratix II gx running some code. It runs at a bout 40 degrees C (maybe slightly less). I then took components off the design, ...
16 years agoThe problem is the board gets hot even if it is not programmed (about 50C).
If I put in the same code as before it gets hotter around 65 C. The peripheral/PLL 1.2V current stays fairly constant with temperature, but the core 1.2V current climbs with temperature, quite predicatably.
