17 years agoStratix II: Coil circuit
I am trying to create a very close range wireless communication using stratix II fpga. I want to achieve that using coil - coil communication. So I connected coil1 to fpga1 with a series resi...
17 years agoHi,
Please dont use 1.6MHz it is the high end of the Medium Wave broadcast band and will cause local interferance, you will be generateing a lot of harmonoics some of these will be in the shortwave region and will go world wide. If you do want to do a home radio link then I would suggest using some radio modules for the unlicenced bands such as 433MHz. A google search for ism 433 mhz gave lots of interesting links.
