17 years agoStratix II: Coil circuit
I am trying to create a very close range wireless communication using stratix II fpga. I want to achieve that using coil - coil communication. So I connected coil1 to fpga1 with a series resi...
17 years ago --- Quote Start --- It's not clear to me, in which regard transmitted power is relevant for your application. Although the coil is a reactive load, part of the power feed is consumed by losses, a part is transmitted to the secondary and a small part is radiated. The general limits for radiated emissions correspond to a few µW RF, to give you an idea of the order of magnitude. --- Quote End --- Thanx for the clarification. I need to measure how much power I am transmitting to try and improve my communication distance. In addition, I will be asked how much power I am transmitting and I need to know how to answer! lol! Could you tell me how to know the power I am transmitting? Its not simply multiply the current going into the coil by the voltage around it, on the resonance frequency, Is it?
