17 years agoStratix II: Coil circuit
I am trying to create a very close range wireless communication using stratix II fpga. I want to achieve that using coil - coil communication. So I connected coil1 to fpga1 with a series resi...
17 years agoI simply suggested to use less turns to achieve resonance with the present capacitive load.
Also the transmitter coil can be operated in a resonant circuit to achieve a higher output level. You don't need EMC tests for a hobby circuit, but you are required to keep the respective regulations. If your device is disturbing e.g. administrative radio-telephony or public broadcast, you can get in trouble.
