17 years agoStratix II and M4K true dual port memory
Hello, I'm using DSP Builder to create 256 true DPRAM (Dual Port Rams) with size 64x10bits. Compilation process places each of them in a single M4K block and I'm very quick out of memory. Is th...
17 years agoHello Sir,
The DPRAM's type in DSP Builder is set to Auto but M512 can not be used for true dual port blocks. Only M4K and MRAMs got this ability. M512 can be set only in a simple dual port RAM mode. Anyway, thank you very much for your response, I'm now quite sure that i need to redesign my project. There is no simple solution. PS. Does anyone got a comparison between Simple and True Dual Port RAMs ? Or at least could point me on most important differences (issues) ? Best Regards Joel
