Stratix GX -> PCI-Express
I am currently dealing with a project that uses the Stratix GX chip for the PCI-Express Interface. Unfortunately, the Altera pcie core I am using does not what to configure. I can see the PC trying to configuration the core on the RX side but there is no response from the Stratix GX.
- Has anyone every successfully implemented the Altera PCI-Express core in the Stratix GX? - Does anyone know why pcie core is not responding to PC's configuration? Thanks in advance.3 Replies
Hi R,
I'm having a similar problem with a Stratix V part. Did you ever resolve your problem? If so how. Thank you, -Jeff - Altera_Forum
The PC starts the neogatiation to L0. However the Stratix GX does not start any link training. From what I can tell the LTSSM on the FPGA does not leave the DETECT state.
Chipset: North bridge - VIA K8M890 South bridge - VIA VT8237A - Altera_Forum
Do you mean that it will not negotiate to L0 in the link training state machine – and not get enumerated by the PC? If so – suggest to run signal tap on the LTSSM to see what the link training state machine is doing. Seen a similar issue troubleshooting now with SII GX. Trying to adjust the RC time constant because NVidia (my chipset) uses a passive receiver detect scheme and I am going to adjust the termination resistance values in Quartus and also try to use an adapter where I cut and jump a series Cap in the receive side to put 2 caps in series in order to reduce the capacitance and change the time constant to see if the chip set detects my receiver.
What chipset are you using?
