OrF
3 years agoStratix 10M DIB Module
Hi
I'm using the DIB to inter connect between the 2 dies of the Stratix 10
I'm using it in BYPASS (therefore I need to define the constraints) mode and one of the IO is transferring clock from ...
- 3 years ago
I cannot seem to get engineering to confirm the values, but the normal practice is by adjustment.
You can start with the values they put for the example design and fine tune it after compilation.
Below are the values used:
- max C=2.65
- min C=-2.65
- max A + max B = 8.25
- min A + min B = 3
- max D + max E = 4.75
- min D + min E = -1.64
Nurina
Nurina
3 years agoHi Or,
Apologies on the confusion. I am discussing on the appropriate usage with the internal team for some clarity.
Can you please share your design for both dies? If it's confidential, you can share it through email. I'm sending you an email, please check.
I would like to understand how the DIB IP is used in your case.
Thanks and regards,
Nurina
