macnicaprasad
3 years agoStratix 10GX
Hi
I am using two Stratix 10 GX L-tile device in my design connecting via through backplane.
chip to backplane and backplane to chip need to send highspeed data rate up to 40Gbps.
My question i...
Kshitij_Intel
3 years agoHi Prasad,
You can use the bit slipper in the L-Tile PHY for word alignment but you need to check manually in soft logic that the correct word alignment is seen.
As for the retimer, it depends on the losses of the backplane. most customers do not need them but they'll need to simulate to assess the need for a retimer.
Hope this will help you.
Thank you
Kshitij Goel
