8 years agoStratix 10 timing analysis
Hi everyone - I'm in the process of porting an Arria 10 design to Stratix 10 and have gotten a bit confused by the new TimeQuest results in Quartus 17.1. Can anyone explain the difference between the...
GuaBin_N_Intel
Contributor
7 years agoNo, it is not an board issue. If not going to use the SmartVID (programmable voltage) , it is supposed that we can ignore those two VID timing corners . Nevertheless, those corners should be more optimistic than 900mV which means that if you can pass the timing in normal corner, it should pass the VID corner as well.
