8 years agoStratix 10 timing analysis
Hi everyone - I'm in the process of porting an Arria 10 design to Stratix 10 and have gotten a bit confused by the new TimeQuest results in Quartus 17.1. Can anyone explain the difference between the...
AndyN
7 years agoThanks for the reply. So this is a board design issue? if you have a -V part but it's just connected to a normal 900mV supply, you can just ignore those two corners?
I'm still not sure I understand how you don't need to analyze the fast vid2 corners - are they strictly "inside" the 900mV corners?
Andy
