EShum
7 years agoStratix 10 Programming Issue
Hello, We are facing a problem programming S10 via JTAG. Example designs: DDR4 and PCIe AvalonST. Messages: 18950 Device has stopped receiving configuration data. 18948 Error message received fr...
YuanLi_S_Intel
6 years agoHi Eugene,
Which PM channel are you referring to? Are you saying the PMBus 0 and etc? If it so, it can be changed, however with limited selection. You can do that in Quartus.
Meanwhile for the wiring part, it is not recommended to do so due to robustness of the board. However, you will need to check with the customer and see whether they accept it or not.
Thank You.
- EShum6 years ago
Power Manager LTC2977 (address - 0x5C) is the only device at S10 PMBUS.
VccINT is at sence channel 4.of LTC2977.
Vcc1.8 is at sence channel 0.
