Volodymir
4 years agoStratix 10 PCI Express Avalon®-MM DMA Reference Design. Interrupt generation.
Hello ! Working with a Stratix 10 board. Per AN 829: PCI Express* Avalon®-MM DMA Reference Design built the design and uploaded it to the board. I work with Windows. I successfully run DMA Read, DM...
Wincent_Altera
4 years agoHi,
You can try to use AVMM code For Qsys-generated Avalon-MM PCIe Hard IP,
- it has up to 16 individual interrupt signals, RxmIrq_<n>[<m>:0], <m>< 16.
- All these inputs will be mapped to one single MSI interrupt output.
- You can create your logic to detect when the wireless frame is received,
- and then use the rxm_irq_i signal to trigger the interrupt. It should work.
- https://community.intel.com/t5/FPGA-Wiki/Handling-PCIe-Interrupts/ta-p/736044
For AVMM DMA,
- the DMA descriptor controller sends an MSI interrupt to the host via TXS interface.
- You need to enable export MSI interface to implement custom MSI interrupt handle
- and send the MSI interrupt via TXS interface,
- I apologize that there is no example for this as I can see.
- As far as I understand, you need to create a MSI (Memory Write) Transaction,
- and transmit it through the TXS interface based on the information that you obtain from the MSI conduit interface,
Hope this answer your question,
Wincent_Intel
