Stratix 10 PCI Express Avalon®-MM DMA Reference Design. Interrupt generation.
Hi ! Thanks for the answer.
You wrote:
……. if you are using rxm_irq_i signal, please noted that These signals are not available when the IP core is operating in DMA mode (i.e. when the Enable Avalon-MM DMA option in the Avalon-MM Settings tab of the GUI is set to On).
My question is in continuation of an open topic
How to generate a custom (MSI) interrupt with multiple sources? And when I need use Avalon-MM DMA?
In progect I will translate rxm_irq_i signals from altera_pcie_s10_hip_avmm_bridge.v module to top level ep_g3x8_avmmdma256_integrated.v.
When using .intx_req_i I only get the legacy interrupt, and DMA does not work because it will generate MSI interrupt.
I am currently using a design that I adapted for my board and that should be very familiar to your team:
Intel pcie example design.
https://community.intel.com/t5/FPGA-Wiki/Reference-Design-Gen3x8-AVMM-DMA-Stratix-10/ta-p/735907
