Volodymir
4 years agoStratix 10 PCI Express Avalon®-MM DMA Reference Design. Interrupt generation.
Hello ! Working with a Stratix 10 board. Per AN 829: PCI Express* Avalon®-MM DMA Reference Design built the design and uploaded it to the board. I work with Windows. I successfully run DMA Read, DM...
Volodymir
4 years agoThanks for your reply.
I have already seen this documentation many times. But I work with Stratix10 Avalon MM PCIExpress with DMA. I will repeat my question. It is as follows: how do I get access to these registers that you link to. Namely Avalon-MM to PCIe Interrupt Enable Register and Avalon-MM to PCIe Interrupt Status Register. Should it be a call through the BAR or is it a call to the configuration space type 0 , type 1 ?
thanks for your reply
