Volodymir
4 years agoStratix 10 PCI Express Avalon®-MM DMA Reference Design. Interrupt generation.
Hello ! Working with a Stratix 10 board. Per AN 829: PCI Express* Avalon®-MM DMA Reference Design built the design and uploaded it to the board. I work with Windows. I successfully run DMA Read, DM...
Wincent_Altera
4 years agoHi,
Thanks for reaching, Apologize that I cannot get your question very clear.
- As I understood from the description, I must first enable interrupts by accessing the PCIe Interrupt Enable Register, which is located at 0x0050.
- Can I know which description and which document that you are referring at ?
- Please tell me how to properly translate the address from BAR in order to access this register from under windows.
- Can you specific which BAR that you need to translate ?
Also, I attach with AN 829 User guide, it might contain information that needed by you.
Wincent_Intel
