yashael
4 years agoStratix 10 PAC HSSI example
I'm trying to understand how to use the hssi interface in stratix 10 PAC. I had some problem on rx_data_valid (PCS Direct on serial loopback) But unable to reproduce the issue, so i'm creating a ...
yashael
4 years agoAfter several seconds, the RX_READY seems to assert well. but I couldn't found the correct data in the rx_parallel_data. using the same code.
Also, in the code, bit no 79 is always set high. Is it not working if we have a valid signal for that particular signal?
